A newsletter is created in an editor, but its success depends on the database that receives it: the target segment, the timing of the send, and the analysis of the results. All in Box’s newsletter software starts with this database, the same one used for your in-store data collection and automated workflows, across all your locations.
For a network, the difference lies in having this single database. Every location adds to the same contact database, the brand can send campaigns without exporting or removing duplicates, and results can be analyzed campaign by campaign.
Terranae: each center sends and measures its own newsletter
Terranae manages a network of shopping centers. For many of them, the network sends its newsletters with All in Box. Each center retains its own database, decides when to send campaigns, and reviews its own results. Terranae monitors performance center by center, rather than relying on averages, essential for knowing which centers are improving and which are falling behind.
At Carré d’Or, the October 2025 newsletter was opened by 21% of recipients and achieved a 0.5% click-through rate.
Book my demo to see a newsletter targeting a segment from your own database.
What newsletter software needs to do when you manage multiple locations
Newsletter software creates, sends, and measures emails sent to a contact list. For a network of locations, it must use a single database, target a specific segment, schedule sends, protect deliverability, and analyze results campaign by campaign. All in Box combines these five features with data collection and automation in a single tool.
A separate email marketing tool treats the newsletter as a standalone channel, with its own imported list. For a retail brand, this list becomes outdated as soon as it is exported: contacts collected in-store the following week are not included, and unsubscribes are not reflected in the customer database. All in Box eliminates this back-and-forth because the newsletter draws directly from the My Data database.
Five criteria to check before choosing
| Criterion | What you should check | What All in Box offers |
| Contact database | A single database for all locations, updated without exports | The newsletter draws from My Data, which is populated by your in-store and online data collection |
| Targeting | Segments based on behavior, area, location, and campaign | Send to the entire database or to a segment based on behavior, geographic area, or participation in a prize draw |
| Editor | A ready-to-send newsletter requiring no technical skills | Drag-and-drop editor, templates, and copy suggested by Eden |
| Sending | Scheduling and deliverability handled for you | Send immediately or schedule for later, with managed deliverability and optimized send times |
| Measurement | Opens, clicks, conversions, unsubscribes, and comparisons | Detailed statistics for each campaign, campaign-to-campaign comparisons, and devices used |
An often-overlooked criterion is performance analysis by location. An overall open rate can hide a store that is falling behind. You need to be able to compare one segment with another, not just one campaign with the previous one.
How to send a newsletter with All in Box in three steps
In practice, it only takes three steps, and you remain in control of each one.
1. Create the newsletter in the editor
Start with a template, drag and drop your content blocks, then add your text, images, and calls to action. The editor uses your brand’s colors and logo. No coding or technical skills required.
Eden, the artificial intelligence built into All in Box, suggests copy based on your topic. You review it, edit it, and approve it. Eden prepares and suggests, your coach provides guidance, and you decide what gets sent.
2. You choose who receives it
You send it to your entire database or to a segment. All in Box builds the segment using data already available in My Data: purchasing behavior, geographic area, preferred store, or participation in a prize draw.
An example for a retail network: you announce a special event that concerns only three out of ten stores. You target contacts associated with those three locations. The other seven receive nothing, and their subscribers do not unsubscribe because of an offer that is irrelevant to them.
A contact acquired through an in-store prize draw can therefore receive their first newsletter without their details having to be entered again. That is what acquiring AND retaining customers from a single database means.
3. You schedule or send
You can launch the campaign immediately or schedule it for the date and time of your choice. All in Box handles deliverability and optimizes the sending time. The results then appear in the campaign dashboard.
The eight steps in the tool, with screenshots, are detailed in creating a successful newsletter.
How to tell whether your newsletter was successful
For each campaign, All in Box provides the open rate, clicks, conversions, unsubscribes, and the type of device used to read the email. You can compare two campaigns and identify what worked.
To plan your next send, you only need to look at three figures. The open rate measures the effectiveness of the subject line and sending time. The click-through rate measures the content and call to action. The unsubscribe rate measures targeting: if it rises, the segment was too broad.
Conversions close the loop when the newsletter leads to a measurable action, such as a booking, an offer redeemed in-store, or a registration. The device used tells you whether your template should be designed primarily for mobile viewing.
Then send the same newsletter to two segments as two separate campaigns and compare the results. A subject line that performs well at one store but poorly at another tells you more about the audience than about the subject line itself.
Book my demo to learn how to interpret a campaign dashboard using your business’s data.
On the writing side, the golden rules of an effective newsletter cover the subject line, structure and call to action.
Deliverability and GDPR: what to set up before your first send
A newsletter ends up in the spam folder when the sending domain is not authenticated, when the list contains inactive or non-consenting addresses, or when the content looks like spam (words in all caps, image-only emails, shortened links). All in Box handles the technical side of sending. The other two factors depend on your contact database and your message.
A clean list starts with proper data collection. A contact who entered your competition and checked the box to receive marketing communications is likely to open your emails. An address imported without consent can lead to complaints, and complaints harm the deliverability of the entire network.
Authenticating your sending domain: SPF, DKIM, and DMARC explained simply
SPF is a record that lists the servers authorized to send emails on behalf of your domain. DKIM adds a signature to each email, proving that it was not altered in transit. DMARC tells email providers what to do when an email fails both checks and notifies you when this happens.
These records only need to be set up once with the provider that manages your domain name. Your All in Box coach will guide you through this step, and together you will verify that the main email providers accept your emails before your first campaign.
What the GDPR requires for a newsletter
For a marketing newsletter, the GDPR requires consent to be obtained before it is sent, an unsubscribe link in every email, and clear information about how the data will be used at the time of collection. All in Box operates in compliance with the GDPR and records every unsubscribe request in the database so that the contact no longer receives newsletters.
Have your legal counsel review your data collection notices and retention period before the first send. Compliant software does not make a campaign compliant: how you collected the contact’s details matters just as much as the tool itself.
The next step is to trigger these sends automatically: marketing automation.
A platform and a team
All in Box is a French all-in-one marketing platform founded in 2018 and based in the Grand Est region. Its newsletter feature is a module within My Communications, alongside SMS, web push notifications, and automated workflows. The same contact database is used across all channels.
The newsletter is only the first message. All in Box’s automated workflows take over from there: a birthday email or a message following a visit to your business. You define the workflow once, and it then runs according to your rules, while you retain control over the content.
A dedicated marketing coach based in France supports you at every stage: planning the send schedule, choosing segments, and interpreting results. Users are unlimited, as is support, and there are no setup fees. Each location can therefore have its own access.
The price depends on the size of your organization, not your level of marketing maturity. Full details are available on the dedicated page: view plans.
Preview your targeted newsletters before sending them
During the demo, you follow a newsletter from start to finish for your own brand: the template in the editor, the segment selected from the database, scheduling, and then the campaign results dashboard. You leave with a clear idea of how much time it takes to send a campaign across your network.
How much does All in Box’s newsletter software cost?
Pricing depends on the size of your organization: very small business, SME, center, or network. Your level of marketing maturity affects the support you receive and which features are displayed, not the price. There are no setup fees, and both users and support are unlimited. Full details are available on the pricing page, and your coach will explain them during the demo.
How much time does a newsletter take each week?
Your time is mainly spent choosing the topic, reviewing the copy suggested by Eden, and analyzing the results of the previous campaign. The layout is based on a template already customized with your brand colors, while targeting reuses the contact groups already saved in My Data. Your coach will help you establish a schedule that your team can realistically maintain, without promising a set amount of time in advance.
Can each location send its own newsletter?
Yes, within the framework you define. Since users are unlimited, each location manager has their own access to All in Box. You decide what they can do: create a newsletter for their contacts or simply view the results for their segment. The brand retains a single database and a shared template, while each location maintains its relationship with its customers.
Can an existing contact database be imported?
You can import your existing contacts into My Data, the database used by the newsletter. Keep proof of consent for each email address: an imported contact who has not agreed to receive marketing communications must not receive newsletters. Your coach will help you clean up the list before the first campaign to protect deliverability across the entire network.
Can a welcome email be sent automatically after collecting contact details in-store?
Yes. A contact collected through a contest or an in-store survey is added to My Data. You create a welcome workflow that sends them an initial email after they sign up, using the message you approved. The workflow then applies to every new contact, and you can track its results just like those of a standard newsletter.
